3 messages.    - 9,6v PP3 battery 230mAh, an invisible upgrade for transmitter ? [6879]
Arf33
03-11-2016 à 12h16
Hi to all,
reading many threads and technical pages here I saw that many people update their TX by using an external 9,6v battery instead the classic 9v alcaline in the original compartment.
surfing on internet I discovered (for me is a news) this battery:
www.mahaenergy.co.uk
seems to be a very good solution because:
- 9,6v rechargeable battery
- PP3 shape, so fit into TX Nikko
- 230mAh
anyones already tested it ?
Anonyme, 26 msg, (IT-21).
 Citer Alerter [103396]
14-11-2016 à 22h42
Hi !
I don't think that it's the most effective improvement for the transmission. The voltage difference will not make the difference on its own. People used 9,6v battery only to have more autonomy and because you always have a 9,6v bat on hand when you have some Nikkos ; I think It's juste more ecological
But using a true RC transmitter or better a 2,4 GHz Tx/Rx combo is a good way to improve the range
 Citer Alerter [103410]
14-11-2016 à 22h42
Arf33
15-11-2016 à 09h23
understood,
anyway I tried it, as you said nothing more for transmission range, but for sure I can have 2 small advantages:
1- it is rechargeable.
2- it last more time before recharging
Alerter [103413]
3 messages.    - 9,6v PP3 battery 230mAh, an invisible upgrade for transmitter ? - Lu 379 fois. [6879]
