41 messages.      1 2 3 4 5   - My Dicator 1 project [6873]
Arf33
27-10-2016 à 21h53
Hi Tchill...thanks
I already saw almost all your video on youtube! Good sharing !
Anonyme, 26 msg, (IT-21).
 Citer Alerter [103368]
28-10-2016 à 06h33
Thanks !!
Gilles, Modérateur,12426 msg, 37 ans. Woustviller (FR-57). [mon blog] www.youtube.com/user/tchillkde
 Citer Alerter [103369]
28-10-2016 à 06h33
Arf33
28-10-2016 à 11h48
sorry guys...
how I can change the small image of my first post in this thread ?
I tried by removing the current one and upload a new one but nothing change...maybe I'm wrong in some step ?
thanks for help
 Citer Alerter [103370]
28-10-2016 à 11h54
Click on "rafraichir le cache" after change the picture . At the bottom of this page.
 Citer Alerter [103371]
28-10-2016 à 12h10
Yes, just a memory lag ..
I can see the new one
Quentin, Modérateur,3654 msg, 24 ans. Chelles (FR-77). [mon blog] Fan de modélisme et sport-auto ! Ingé Motoriste. Mes vidéos: www.youtube.com/user/thelastlegend77/videos
 Citer Alerter [103372]
Arf33
28-10-2016 à 13h40
yeah !!!
correct...thanks
 Citer Alerter [103373]
25-01-2017 à 15h33
how,impressionnant!!!
Stephan, 5414 msg, 43 ans. Aigues Mortes (FR-30). [mon blog] a quand la réédition de notre superbe dictator???
 Citer Alerter [103591]
25-01-2017 à 22h41
Ouais il bosse super bien le gars la.
 Citer Alerter [103603]
redondo
28-01-2017 à 12h55
Great job! As you've noticed, the weakest point on this model is the ABS chassis, but your job is well going on.
To make your car bulletproof, the only thing that remains is to make some more solid front and rear damper stays. The original plastic ones are very fragile!
Anonyme, 327 msg, (FR).
 Citer Alerter [103605]
28-01-2017 à 12h55
bapman
19-04-2017 à 19h27
Quelle est la référence des amortisseurs avant et arriere ?
As-tu un lien ? Merci !
Bapman, 388 msg, 37 ans. Nancy (FR-54).
 Citer Alerter [103745]
41 messages.      1 2 3 4 5   - My Dicator 1 project - Lu 5748 fois. [6873]
