41 messages.   1 2 3 4 5   - My Dicator 1 project [6873]
17-10-2016 à 12h22
Good brushed motors are very rare now, brushless have totally replace them ...
Your ESC is good enough for 2 LRP 380, even for two normal 540 type motors
Quentin, Modérateur,3653 msg, 24 ans. Chelles (FR-77). [mon blog] Fan de modélisme et sport-auto ! Ingé Motoriste. Mes vidéos: www.youtube.com/user/thelastlegend77/videos
 Citer Alerter [103321]
Arf33
17-10-2016 à 13h02
ok, thanks for this confirmation.
I'll start with the 2 Race400 I have...I will think about further improvement later
Anonyme, 26 msg, (IT-21).
 Citer Alerter [103322]
17-10-2016 à 13h02
Arf33
17-10-2016 à 17h48
just in case I will not be able to find at reasonable price 2 LRP motors which is the best brushed motor in 380 size ?
I already know those brand/types for 380 series:
- Traxxas Titan 380 (easy to find, 12-20€ each)
- Graupner Speed 400 4.8-6-7.2v (easy to find, 9-10€ each)
- AeroNaut Race 400 6-7.2v (already I have those, 11€ each)
- Tamiya Sport Tuned 380 (easy to find, 10-13€ each)
- LRP Fusion micro 380 HT (hard to find below 28€ each)
- Carson Toxic 12x2 (hard to find now)
- Multiplex Permax 400 6v (easy to find, 9-10€ each)
- Xtreme 380 Modified Brushed Motor EHB005 (maybe not correct for voltage)
- Atomic 380 High Speed (hard to find it, expensive 25-30€ each)
- Atomic 380 High Torque (hard to find it, 12-20€ each)
more choices ?
 Citer Alerter [103323]
17-10-2016 à 18h49
LRP fusion hs is the fastest, the ht is the best for a Dictator.
The Permax is under, but it's normal : the LRP as almost the same power as a 540 type.
The Graupner is a bit under the Permax.
The Tamiya Sport Tuned is under too.
Traxxas Titan is simply bad.
Carson Toxic is a 540 type.
No experiences in my knowledge for the others
 Citer Alerter [103324]
Arf33
18-10-2016 à 02h13
95% I find the LRP but in HS version... better than nothing I think
If the shop will answer to my email I can buy them for 9.50EUR each!
I will update about
 Citer Alerter [103325]
Arf33
19-10-2016 à 17h10
update about LRP motors...
seems very hard today to find them, also at the spanich shop were are indicated "as available" it's not possible to perform the buy because ITALY is not included in the countries for shipment.
anyway...since I'm not sure to get the LRP I just ordered a couple of Permax 400 6v
then I will make 3 speed test, one with original 380 motors, one with Race 400 6v and one with Permax 400.
bye
 Citer Alerter [103327]
19-10-2016 à 17h19
The results will be interesting, wanna see the difference with the Race 400
 Citer Alerter [103328]
Arf33
21-10-2016 à 12h23
last minute updating:
I've just bought 2 LRP Fusion HT from Spain
so I have:
2 Mabuchi 380sh standard motors (original)
2 Aeronaut Race 400 6v motors
2 Graupner Speed 400 6v motors
2 LRP Fusion Modified 380HT motors
 Citer Alerter [103334]
21-10-2016 à 13h31
And soon 2 Donkey ST380L from Hobbyking
 Citer Alerter [103335]
21-10-2016 à 13h31
22-10-2016 à 09h37
for me the LRP H.S is better than the H.T .
 Citer Alerter [103336]
41 messages.   1 2 3 4 5   - My Dicator 1 project - Lu 5721 fois. [6873]
